API code with customized settings including latitude, longitude, current conditions, and more
Simple. Powerful.
With both REST and WebSocket endpoints, you can tap into the Tempest API on demand or you can get information as it happens in real-time. Whether creating a simple data feed for one station or a full-blown application for millions of users, the Tempest API is all you need. The best way to get started is to buy a Tempest Weather Station and start using data from your own hardware, but you can also play around with our interactive developer documentation even if you don’t own a Tempest yet.
How it works
While Tempest apps and official integrations offer ample functionality and a wealth of uses, our API enables you and your team to create custom integrations for the decision tools you use internally, the products & services you provide your customers, and whatever else you may dream up!
What’s available in the API? Everything you see in the Tempest apps and personal apps...and more. Here’s a summary:
Current conditions and observations
(all measured & derived values)
Includes stations in the Tempest network as well as over 100,000 other surface observing stations from public and private networks.
Forecasts
(at all Tempest Station locations and any point on Earth)
Includes the Tempest guaranteed better forecast as well as dozens of other forecast models from NOAA and other government sources.
Statistics
Daily, weekly, monthly, annual, and all-time high/low/averages.
Metadata
Name, location, elevation, sensor capabilities, etc.
Lightning strikes
Location, type, strength, and timestamp.
Radar and Satellite imagery
Including global Sea Surface Temperatures.
Sea Surface Currents and Tide Data
For select regions & locations.
What is the Tempest API?
The Tempest API provides access to real time and forecast weather data from Tempest weather stations.
Does the Tempest API support live data streaming?
Yes. The API supports both REST requests and real time WebSocket data.
What data is available through the Tempest API?
The API includes weather observations forecasts lightning data and station metadata.
Do I need a Tempest weather station to use the API?
No. Developers can explore and test the API without owning a station.
How can we help?
Our experts are available to answer questions and assist with custom solutions for your business.
Contact Us Now
