heat-safety
Practicing Heat Safety
The TempestOne Heat Safety Kit, compatible with Disney Heat Check, delivers real-time, onsite heat and weather insights — empowering you to make informed decisions that safeguard employees, customers, and visitors from heat risks.
  • Keep your community safe by issuing public heat advisories, open cooling centers, and preparing for heat-related community emergencies.
  • Leverage OSHA's National Emphasis Program with a Heat Safety Kit to implement work-rest cycles, increase hydration access, and adjust work shifts.
  • Use the Heat Alert Mobile App and Heat Safety Kit to track localized Wet Bulb Globe Temperature (WBGT) readings and adjust athletic activities accordingly.
Heat Safety Solution
Heat Safety Kit
At the core of the Heat Safety Kit is the revolutionary, compact Tempest weather station that provides Wet-Bulb Globe Temperature plus precise measurements of temperature, humidity, wind speed, solar radiation, and lightning, as well as a suite of other standard weather variables.
AI-powered forecasting—leveraging cutting-edge machine learning, delivers precise, hyperlocal forecasts that adapt to changing environmental conditions. This enables proactive heat risk management and smarter decision-making, hour by hour.
Heat Stress Metrics
Current and forecasted heat indices are included with the TempestOne Heat Safety Kit to help you make the most informed decisions around heat safety:
  • Temperature and Dewpoint - measured meteorological parameters temperature and dewpoint data.
  • Heat Index or Feels Like Temperature (when combine with Wind Chill) - a derived measure of heat-stress based on temperature, relative humidity, and wind speed.
  • Wet Bulb Globe Temperature (WBGT) - a derived measure of heat-stress based on temperature, humidity, wind speed and sun exposure.
Get Heat Safety Insights
Keep employees, customers, and visitors safe by tracking real-time heat index conditions and AI-optimized forecasts directly in the Heat Alert app. Use the app to stay informed, prevent heat-related risks, and make smarter decisions when it matters. Combine with TempestOne Heat Safety Kits for the most accurate on-site decision making tool.
What is the TempestOne heat safety solution?
It is a weather monitoring system designed to track heat stress and unsafe temperature conditions in real time.
Does Tempest measure Wet Bulb Globe Temperature?
Yes. TempestOne calculates WBGT using on site weather measurements.
Can Tempest support OSHA heat safety guidelines?
Yes. Tempest provides data used to guide work rest cycles and heat safety decisions.
What is the HeatAlert app?
HeatAlert is a mobile app that displays real time heat risk levels using Tempest weather data.
Find Out More
Our experts are available to answer questions on our Heat Safety Kits and the Heat Alert app. Contact us today.
Contact Us Now
